How to speed up loading and performance of Your axon 7
Go to settings
about phone
click x times on build number to activate developer options
go to developer options
go to Logger buffer sizes
change from nominal 256k to 1M
VOILA
score in antutu went from 80K to 140K
it will help overall performance of the phone
i did notice laag in web browser when You try to scroll ,not anymore,,
  • mrbigscreenmrbigscreen United KingdomPosts: 266
    what does changing the 256k to 1M actually change? from the point of view from someone who doesnt know what logger buffer sizes do/manage does pushing it higher than 1M cause issues
  • xblackdemonxxblackdemonx CanadaPosts: 102 ✭✭✭✭
    88K @256k
    87K @1M
    It doesn't work
    EDIT: I unplugged my Quick Charger and I went to 138K!
  • supraketsupraket Mumbai, IndiaPosts: 94 ✭✭✭✭
    Would it, by any chance, consume more battery?
  • rikkkurdrikkkurd United statesPosts: 318 ✭✭
    Great tip!
  • I got 124k. Is this close ? I don't know if that means it's close or far away.
    I haven't checked my Antutu score since the day i got it.  It was a touch higher than 142,000. Here is my new score:
  • Wonder what happens if you pick the higher numbers like 4m or 16m.
  • MicoMico MiamiPosts: 7 ✭✭
    edited January 20, 2018 1:19PM
    It doesn't change much.
    I tried 256k, and the highest 16M and lowest 64k.
    Antutu 6.2.7 showed around 145-146k score. Why there is no difference?
    ps. I didn't restart the phone after changing this option. Maybe that is why as it needs a restart every time?
    thx
