Zmax Pro UI tuner doesn't work
g239mg239m Posts: 24 ✭✭✭
I can get it to spin, sometimes, but then it does nothing else nor gives me other options, has anyone had any luck getting it to work?
  • g239mg239m Posts: 24 ✭✭✭
    I may have set it up before because I can see a pencil icon that can change the tile positions, but I can't access it from settings nor add or remove tiles, just move them around.
