USB Connection Not Showing Properly
rczmaxprorczmaxpro Miami, FLPosts: 2
When phone is usb connected is not recognized by iTunes and when using Device Manager (W10) it shows up a "USB Mas Storage Device".
I have been trying to transfer some music files from my PC and iTunes and not able to do so with drag and drop as I have done before with another Android phone.
Here is and image of how it now shows up in DevMngr. When I first connected the phone it showed a little phone icon and the two memories in it.ZTE AS USB STORAGE DEVICE.PNG
  • musicdjmmusicdjm United StatesPosts: 3,113 mod
    When you plug in the cord are you using the included USB-c cable ? Also do you see the prompt pop up that asking charge only, install drive , connect as MTP device or camera device?
  • rczmaxprorczmaxpro Miami, FLPosts: 2
    Thanks for your reply.
    The answer is yes to each of your questions. At the pop up I have selected  connect as MTP drive and at another instance I have selected Install Drive.
    Should I Disable of Uninstall and reconnect via USB cable and Windows 10 or the phone will reinstall the driver?
