Remote Control option not showing up
I can't seem to find the option to turn the remote on.
I checked these settings:
Projector Settings > (4th Paragraph Bubble) Remote
But all that's shows up in the 4th bubble is:
Advanced user with CAIC settings, LABB settings, Color correction, Anti-shake, and G-sensor sensitivity.
No remote control selection.
I tried Factory Resetting it but nothing changed and tried the manual update but the update didnt work.
  • sshasansshasan Staff Member United States Posts: 4,078 admin
    Can you let me know the model # of your SPRO 2.
  • Thank you for responding! The Model # is MF97B
  • ironbaybeedollironbaybeedoll United States Posts: 4,627 mod
    Good afternoon. I am looking into this further, for you, and will get back to you shortly. Should you need anything else please let me know. Also as a side note, responding by using the @ Symbol directly before a username will allow that person to see your comments much faster
    Good evening. Are you able to tell me what build you are on? Settings>About Device>Android Version. Thank you.
  • Thanks again for looking into it!
    The Android Version is 4.4.4
    (Baseband Version- MF97BB01)
  • monger80monger80 United StatesPosts: 663 ✭✭✭✭✭✭✭✭
    ​, what is the Software Version of the device?  Also, the option for Remote Control should be between Color Correction and Anti-Shake.
    ​ Good Evening. I am still with you on this. When you attempted to update your device, does it give an error?
  • The SW Version is: MF97BV1.0.0B15
    And for whatever reason there is no remote control option there, that's what I'm trying to figure out.
    Thanks!
  •   The update worked perfectly and now when I go to update it, it says "Current Software is up to date".
    the latest update for the AT&T model of the SPro 2 is B24.
    The SD Card update can be found on the support page here ZTE Spro 2 (AT&T) - ZTE USA
    Once installed you should be able to find the option for the remote control.
