bluetooth was synced sometimes there would be sound coming off the speaker and a few minutes later the sound wouldn't work..
had to restart it and even factory reset. it still has issues with the bluetooth speaker not producing any sound even while paired.
need help please
thank you
i'm using zte spro2 smart projector
i just want the bluetooth to have sound while paired
what's causing the sound to not work?
Hello, and Welcome to Z-Community. I have had this issue, but only with a bluetooth speaker that was problematic to begin with, and died within a month or so of this behavior starting. I haven't experienced it since, and I switch between two different speakers. So I would definitely see if this happens with another speaker if possible. Assuming that the problem persist, please post back with which model and build you are using, and we can attempt to troubleshoot further.
only solution that should bring things back to normal.
what version of SPRO2 ?
