What happens to the ZTE Quartz after 10 minutes in water
Answer is absolutely nothing, the ZTE Quartz is IP67 rated and should last up to 30 minutes submerged in 1 meter of water. If you had any questions about if the Quartz can stand up to some water maybe this will give you some reassurance. I submerged mine for 10 minutes and took a timelapse video using the Axon 7. I did a timelapse so you wouldn't have to sit through 10 boring minutes of video, and I figured 10 minutes was long enough to prove the point.
