[How To] Do Not Disturb Mode - ZTE MAX XL
sshasansshasan Staff MemberUnited States Posts: 3,771 admin
You can limit sound interruptions with Do not disturb mode, which silences unwanted sounds from your phone.
To turn on Do not disturb mode:
1. From home, tap Apps 3o6Ztck2gFAL04gOrK - Edited.png > Settings unnamed.png   > Sound > Do not disturb.
2. Tap Do not disturb and select Always or Scheduled.
3. Set the detailed settings.
    • If you have selected Scheduled, set the days and start/end time during which Do not disturb mode should apply.
    • Tap Disturb rules to determine whether you allow exceptions.
    • Priority only: Disturbance set as priority interruptions are allowed.
    • Alarms only: Put your phone in silent mode in which only alarms sound is allowed.
    • Total silence: Forbid all disturbances.
  • If you have allowed priority interruptions, customize the types of allowed sounds or vibration in the Priority interruptions section.
