Research project could bring quality VR to phones
frodriguez2010frodriguez2010 Enterprise Tech Support EngineerTexasPosts: 1,904 ✭✭✭✭✭✭✭
Virtual Reality or VR hardware appears to make a huge impact over the next couple of years, but there’s still the question of how to expose mainstream audiences to this type of experience. Samsung and Google have found some success by using smartphone hardware to power the content, and now it seems Microsoft might be following suit.
In about a month, a team comprised of representatives from Microsoft Research and Rice University will present a paper called FlashBack: Immersive Virtual Reality on Mobile Devices via Rendering Memorization in Singapore at the MobiSys 2016 conference. The paper outlines new methodology that could make it easier for hardware like smartphones and low-end PCs to run VR content well.
The concept hinges around the user’s perspective. Instead of rendering 3D objects in real-time, the "FlashBack" system would utilize a library of compressed frames that look at the object from all possible angles.
When the user looks at a 3D object, they’re actually looking at a still image of it taken from their perspective. The device would only render what the user can see from that angle, which cuts down on all non-essential rendering of the wider environment.
Tests outlined in the paper demonstrate that "FlashBack" could make VR available to a much wider range of hardware. A prototype version apparently offered sizable improvements over a locally-rendered VR set-up, making frame rates eight times better while reducing energy consumption per frame by a factor of 97 (remarkably), and reducing latency by a factor of 15.
Unfortunately, there’s some way to go before it is ready to be implemented. Restrictions relating to file sizes and methods of compression mean the system isn’t quite ready for a mass implementation — but once these issues have been sorted out, FlashBack could help Microsoft bring VR to the masses.
  • Just wish it didn't look like your going scuba diving. Gotta be another way to miniaturize this.
    Great point.  It does appear as if you are going diving.
  • runtohell121runtohell121 Analyst United StatesPosts: 2,250 ✭✭✭✭✭✭✭✭
    There is a smaller VR from LG... only works with LG phones though I think and it's one of the few that doesn't actually use your phone's display, instead it is a built in display in the VR headset.
  • fzrrichfzrrich United StatesPosts: 4,254 mod
    I've seen foldable VR glasses on line somewhere....wondering if it will ever be viable. Maybe a mixture of google glass and a vr headset without using your smarphone. I'm sure that if VR takes of like most of think it will then our next generation of kids will be wearing regular glasses enjoying a similar experience.
    That would be awesome.
  • rikkkurdrikkkurd United statesPosts: 318 ✭✭
    wauw this is great research!
