Audio Through USB Port
wwsiralexdwwsiralexd Posts: 29 ✭✭✭✭
edited July 30, 2017 9:26PM in Blade V8 PRO
Does this phone play music through the type-C port?
Thank you.
    How exactly would you be playing audio through the USB-C port. I don't have this phone so I cannot say for sure, but my experience in the past has been if the phone has a headphone jack then using a USB-C headphones still works. However, using a USB-C to 3.5mm adapter will not work unless the headphone jack is missing.
  • wwsiralexdwwsiralexd Posts: 29 ✭✭✭✭
    Thank you.
    Does it have a headphone jack?
    Yes, it does have a 3.5mm connector.
    I have an external DAC. I want to see if I can get music to play through the DAC.
    @wwsiralexd said:
    Thank you.
    Since it has a headphone jack why aren't you using it?
    The external DAC I have produces better music than the headphone jack.
    I am delighted to find out that the type-C port on this phone does play music.
    Thanks @wwsiralexd for letting us know it worked.
    @jimlloyd40 another reason for wanting this to work would be future proofing. Buying a USB-C headset now will future proof your purchase since it appears 3.5mm headphone jacks will likely be dead soon.
    Glad to "hear" it worked out @wwsiralexd
