New ZTE blade x Max
Dgk196Dgk196 CaliforniaPosts: 4 ✭✭✭✭✭
I have had my phone since July 22 and every time I click on a app or anything my screen flickers like it's being double clicked. Is there a way to fix it? Also can I move apps to SD card?
Best Answer
    Accepted Answer
    You can always do what works for a multitude of problems and that is wipe the cache partition in recovery and clear the main storage cache in the storage settings and then reboot. If that doesn't help then a factory reset. I don't have that phone so I don't know about moving the apps to the SD card. Are you aware that when you move an app to a SD card only about half of it is moved? The rest of the app stays in the internal storage.
  • Dgk196Dgk196 CaliforniaPosts: 4 ✭✭✭✭✭
    Yeah but I moving downloaded or pics that are supposed to save to SD card and not device. I have done all that trouble shooting and still does it
    I'm verifying, but you cannot move apps to SD card on the Blade X Max. Pictures, you should be able to. Open the camera app, go into camera app settings, and look for save location. Hope that helps.
