When I look up anything it shows me results but when I click on the link I want to access it opens google play. I've cleared the cache on apps and play store WTF. I've had phone for 7 days so they won't refund my money. Please help
How do I wipe the cache partition in recovery? No clue at all
Figured out and wiped cache partition. I will post any further problems. Thank you jimlloyd40
It did help, but only temporarily. Every day at some point I have to wipe cache partition. Don't know if I got a bad phone or if this phone has lots of problems for everyone. Thanks for your help
hi, @thenderson37 , when you said you look up anything, do you mean using Google Chrome browser and search for something there? Or Were you using the search bar widget?
have you try to do a factory reset to clear up any potentially software issue? Sounds to me that there maybe some sort of software issue and factory reset will get it fixed. Once you reset it, try to only install essential software to start with to see if problem went away, if it does, it maybe some apps that you have installed that could possibly causing the problem.
