ZTE Axon 7 - Power Management of apps!
boxallboxall Posts: 2 ✭✭
The auto-closing of apps during screen locking is causing me grief with a Samsung Gear Fit2.
There is a Gear Fit plugin that it uses to maintain connection. It is not listed as an app I can apply power management to, so it gets shut down.
Any ideas what I could do?
The app is listed in the battery cooling section as a running app however.
  • samsamhasamsamha United States Posts: 2,093 ✭✭✭✭✭✭✭✭
    hi, @boxall , I do not have Gear Fit 2 to test.
    Though, in Settings->Power management->Power management settings for apps->
    tap on the samsung gear fit 2 app and turn off the allow screen-lock cleaning and allow deep sleep.
    Also, under the same power management settings for apps, go to the 3 dot menu on the upper right corner, and select power-lock cleaning. Here you can choose what app that you do not allow screen lock cleaning.
  • boxallboxall Posts: 2 ✭✭
    Thanks for the feedback. The Gear Fit plugin is the "app" being shutdown. BUT it is not listed in power management on the ZTE. That is the issue.
  • stevec5375stevec5375 TexasPosts: 805 ✭✭✭✭✭✭✭
    Did you tell it to display the "system apps"?
