Newest Consumer Research Invitation: AR Consumer Research Survey
Welcome to our Beta Lab page. While we currently have a dozen or so private beta tests running, there are no active projects that we're recruiting for.
Check back often for recruiting surveys and screeners for new beta projects.
Bluetooth Exploit: when does ZTE plan to push update for fix?
riverive Posts: 59 ✭✭✭✭✭
edited September 13, 2017 12:46PM in Off Topic
Seems there is a known and recently made public exploit for Bluetooth on Android phones.
The exploit allows remote takeover of a phone if Bluetooth is enabled/turned on, and device is within range (e.g, coffee shops, public places, in vehicles (if say you are using bluetooth car speakers), or anywhere else you may go (if say you use a bluetooth headset).
So when does ZTE plan to push an update that includes the Google fix for the exploit to the Axon 7/Axon 7 Mini? Apparently the fix was sent last month (August, 2017) to ZTE from Google.
https://www.google.com/amp/s/www.theverge.com/platform/amp/2017/9/12/16294904/bluetooth-hack-exploit-android-linux-blueborne
