Exist patch for blueBorn on ZTE Blade V6
Somebody can help me to know any solution for malware blueBorn on ZTE Blade V6.
Thank you.
  • Thank You @jimlloyd40 , I think that my phone is abandoned.
  • DoppelgangerDDoppelgangerD Master Of Ceremonies United StatesPosts: 1,576 ✭✭✭✭✭✭✭✭
    Thank you.
    Your device was released almost 2.5 years ago, so it is doubtful that it will receive any further updates.
    It is highly unlikely that any single device would be affected by Blueborn in the short term.
    For anyone who is worried about that issue, and hasn't received an update to their device to patch it,
    the only advice to offer is to just keep Bluetooth turned off in your phone while not using Bluetooth.
  • alonsogjaalonsogja Posts: 4 ✭✭✭
    edited September 28, 2017 8:48PM
    Thank you for your answer @DoppelgangerD, for the moment I think that is the best action to protect me from the Blueborn. I will try install a "Custom Rom" for the ZTE blade V6 (I will use marshmallow), maybe my phone survive almost one year, I don't know but i will try do it along this week. If there is luck I will tell you.
    edited October 16, 2017 7:25PM
    Well, I've been tried install a custom rom with android Nougat and Android Marshmallow and the result is negative. The solution for me was a install a firewall for Bluetooth.
  • How to update zte blade v6?
    Pls Help mee
  • sshasansshasan Z-Community Moderator New YorkPosts: 3,409 admin
    This device is not supported in the US.
    Please reach out to ztedevice.com for additional support.
    Thread locked.
