Low ringtone volume
ringtone volume low even when all volume switches turned up max.
    Are you using one of the default ringtones, or a custom one? If you are using a custom one, to maximize the volume, it needs to be normalized to 0dB and if it is a sound file not designed to be a ringtone, then the best method of maximizing volume is to use an audio editor and run a multi band compressor to get all of the audio generally to the same levels without any peaks that are significantly louder than the rest of the track.
    After doing that, you can normalize to 0dB,
    Outside of that, the stock ring tones are loud, though they will start quiet if you have have the option enable to gradually increase the volume on the ringer the longer the call goes unanswered.
    Also make sure you did not adjust the EQ in dolby atmos to attenuate the audio.
