ZTE Axon 7 - specific calls are "unidentified" as neither incoming or outgoing after upgrade to B32
sbisbi Posts: 49 ✭✭✭✭✭
As the title says - calls from specific people are not identified as neither incoming or outgoing, showing an orange icon of a handset with question mark. As a result, the "missed calls" number in the Phone App never rest.
Anyone else have this issue and how do I fix it?
Is there a way to roll back to B25?
Thank you.
  • musicdjmmusicdjm Worcester,MAPosts: 3,104 mod
    Are you answering calls through your vehicle or through a smartwatch ?
  • sbisbi Posts: 49 ✭✭✭✭✭
    Neither, answering on my phone, talking on my phone.
    other than the suggestions above your other option is to wait until the next update gets pushed out which should be soon
    Is there any way to roll back to previous version of Android?
    Anything on this?
    I can't imagine I am the only one who has this problem of specific contacts that the Axon cannot recognize whether or not they called me or I called them.
    Any way to roll back to previous build?
  • DoppelgangerDDoppelgangerD Master Of Ceremonies United StatesPosts: 1,576 ✭✭✭✭✭✭✭✭
    edited November 16, 2017 6:23PM
    @sbi said:
    Anything on this?
    Did you ever try the suggestions posted above?
    I believe I had this issue at one point on my A7, but it kind of fixed itself or I just don't recall how I fixed it.
    I also use the HiYa app for identifying calls, but not sure if that makes a difference in this case or not.
