Axon 7 GPS Problem
weswes Eskişehir, TurkeyPosts: 38 ✭✭✭✭✭
You can check my problem on video.
  • DoppelgangerDDoppelgangerD Master Of Ceremonies United States Posts: 1,845 ✭✭✭✭✭✭✭✭
    Hi @wes. Because the animations in your video are so fast, it is difficult to see what you are referring to.
    Can you please explain what your video is highlighting? thanks.
    After slowing the video down, the only thing I can decipher is that your "location" services are staying on after you turn off GPS?? If so, GPS is not the only determination for location, it's also using wifi, bluetooth and cellular. It was also using GPS until you turned the GPS off.
    Other than that I'm not sure what you are pointing out.
