FTM
mrterry20784mrterry20784 herePosts: 13 ✭✭✭✭
Why does this appear when attempting a reset?
  • mrterry20784mrterry20784 herePosts: 13 ✭✭✭✭
    max xl . Battery cannot be removed
    yes I did it keeps going back to the FTM screen . max xl 9560 . It is not rebooting
    thank you for your advice
    yes I am only holding the power button in .Well not reboot after holding for 1-2 mins. The FTM comes back up on the screen . If there is a reboot option I do not see it.
    I'm pretty sure in FTM that there is an option to reboot on the screen. I just went through this on a friend's phone and there is an option to reboot in FTM.
    What are the options?
    to exit please long press the power key. avoid pressing volume up key when turning on handset
    There also has to be other options listed.
    There are not any other options listed. I cannot get to hard reset screen or any other screen except FTM. Unless there is another way to access it . I followed directions from CS
    other then sending back to zte for 3 weeks and Boost Mobile not being any help , recommendations ?
  • ironbaybeedollironbaybeedoll United States Posts: 4,627 mod
    @mrterry20784 Have you tried pressing Power and Volume Up to go to recovery menu?
  • DrakenFXDrakenFX Mobile United States Posts: 2,098 ✭✭✭✭✭✭✭✭
    edited December 16, 2017 11:08PM
    @mrterry20784
    If you have ADB install on your PC if not you Google minimal adb and do this :smile:
    • Open cmd / command prompt
    • Type either of the following commands
    • If you want to boot to recovery
      adb reboot recovery
    • If you need to boot to system
      adb reboot
    That should help you get off FTM
