Blade x max screen casting
Received this phone as a Christmas present. Does this model have screen casting abilities? If so, where and how?
  • I was thinking the same and watched that video. There is no cast in my display under settings, and I have no ideas where to look for software updates.
  • lparran1lparran1 United StatesPosts: 2 ✭✭
    Same here this is the third post that I visited here.  STILL NO ANSWER🙁
  • samsamhasamsamha United States Posts: 1,867 ✭✭✭✭✭✭✭✭
    hi, if there option is not there in the setting or quick setting menu, then it is not officially supported. Sometimes you could still get the phone to cast to your TV (assuming you have a device that support miracast) by downloading apps from playstore (just search for miracast) that adds a shortcut to allows you to toggle the function on and off.
    This is no guarantee that it will work but I was able to get it done with some of the devices I have despite the fact the setting is not there. FYI, in order for the cast to work, both your phone and the TV needs to be on the same wifi network (ie both have to be on 2.4ghz or 5ghz).
