Problem downloading images
ashleyv567ashleyv567 Tulsa, Oklahoma Posts: 3 ✭✭
I'm using a ZTE Sonata 3 it worked great, until a couple weeks ago, images I download won't appear in my gallery. Does anyone know how to fix this? Please help!
    When you save the image, is a file explorer able to view the image in the location where you saved it (this is to check if the images are actually being saved and not a blank frame or spacer that some websites may use to prevent people from easily downloading images.
    Also, if you restart the phone, does the gallery application suddenly start populating with images that were previously downloaded?
  • ashleyv567ashleyv567 Tulsa, Oklahoma Posts: 3 ✭✭
    I can see the image in my downloads, but I can't actually see it in my gallery, this is the first time it's happened.
    Also, my phone is having other problems, the date and time is messing up. The images I download only appear in my downloads but not In my gallery.
