Bluetooth Devices Not Showing Up
I just got this phone, and my Bluetooth Devices won't connect. I've tried a Pokemon Go Plus and a Plantronics headset. Any ideas? I already turned off Bluetooth and Wi-Fi scanning for location.
  • razor512razor512 United StatesPosts: 2,502 ✭✭✭✭✭✭✭✭
    Are you putting the Bluetooth headset in pairing mode?
    Also in the Bluetooth settings menu, did you click on the 3 vertical dots in the upper right hand corner of the screen, and then click on "Refresh"?
  • I did hit refresh. When I first paired the headset on my last phone I just turned on the device and there it was. With the Go Plus, the app recognizes that the device is there, but I get a "wrong pin or passkey" error.
    Usually if a Bluetooth accessory has been paired before, there will be additional steps to get it to re-pair, for that, you will need to check the instructions that came with the headset, as well as the pokemon go plus device to see how to manually place them in pairing mode.
