Looks like we have a System Update for the Blade Zmax awesome thanks ZTE👍
paultechpaultech CaliforniaPosts: 23 ✭✭✭✭✭
Looks like it's the February 5th 2018 security patch
  • RoverRover DallasPosts: 77 ✭✭✭✭✭
    edited February 27, 2018 6:55AM
    I have a different Kernel version, but I don't know if my Build number is different. What's your Build number/Hardware version?? If you take the snap shot of the screen, but move the screen up first, the snapshot will capture the Build number/Hardware version.
    Here's a screenshot I took:
  • coldheat06coldheat06 Fort Worth, TexasPosts: 1,638 ✭✭✭✭✭✭✭✭
    @Rover the new Build number is B20
  • angelpangelp United StatesPosts: 18 ✭✭✭✭✭
    I still haven't got the update :neutral: anyone else with me
  • hollaphollap Wisconsin USAPosts: 7,931 ✭✭✭✭✭✭✭✭
    I just got mine today.
  • Raiders4Life90Raiders4Life90 Santa MariaPosts: 1 ✭✭
    I didn't get the new software update.
    edited March 4, 2018 3:11PM
    @Raiders4Life90 most updates are rolled out in phases so you should receive yours soon. You could also try to manually changing your date on your phone to something in the future (try a few weeks ahead) and see it that will force it...... just don't forget to change it back..
    I received my B20 Build/Upgrade to the Feb. 5, 2018 security patch today!
  • mbroman12mbroman12 Posts: 7 ✭✭✭
    I switched to Tmobile, ZTE informs me that I need to switch back to MetroPCS to get the updates, what a racket! It's farcical. Anyone has any idea to get around this?
    That's a very slow roll out but at least you finally got it @Rover. What's your verdict on the update?
    I feel like the phone applications are running faster. I'm good with the update.
    Yes and also the memory management seems to be improved. There are a few other things that were fixed also so this was well needed update
    I agree, much improved memory management and battery life for me.
    Could anyone comment as to whether or not videos and music are still pausing?
    I never had this issue.
