Help with ZTE N817 Phone Weather Widget
I cannot get the Accuweather widget on my N817 phone to show either time or weather info. This has been a problem since last Thursday yet happens a lot!!!
I've turned phone on and off and restarted it to no avail.
Any suggestions, tech wizards???
  • MarinoX1MarinoX1 United StatesPosts: 1 ✭✭
    The same thing happened to me. I removed it and put it back on the home screen with no luck. Unfortunately I had to do the unthinkable and factory reset the phone and re-do the system updates (prl, profile, zte software and firmware). It actually did wonders for the phone. It now runs so much better than before. Realistically this phone is bare bones with barely enough memory to run it and not much storage space for apps. If you use it, Facebook alone consumes most of the resources. Play store has new Facebook app (Facebook Lite & Messenger Lite) that are easier on the memory and storage.
