Tech Specs for Velocity 2
amcnabbamcnabb United StatesPosts: 1
Hello, I'm trying to find the complete tech specs for the Velocity 2. Specifically, if the unit supports 2X2 or 4X4 MIMO and what antenna ports the device has (I'm assuming TS-9). The user manual and info sheet have limited info. Thanks!
    edited March 21, 2018 8:48PM
    In searching, it does seem that there is not much in the way of detailed specs (pretty common for carrier devices sadly).
    Based on the FCC reports, it seems like it would be a 2 stream 802.11ac radio, thus at best, 866Mbps PHY rate, which will likely translate to around 450-500Mbps throughput in the real world if close to the unit.
    It does support MIMO on its 2 stream radio, though with or without MIMO, the bottleneck is pretty much always the WAN connection and not the WiFi radio since even with the usual multiplexing used to handle multiple clients (10 max for the hotspot), the overhead will likely never reach a point where it will bottleneck the WAN connection.
    LTE Bands
    2, 4, 5, 12, 29, 30, 66
    UMTS/HSPA+ MHz
    850/1700/1900
