I need a new charger for my Zmax Pro.
niellaniella United StatesPosts: 1
How and where could I find one? The cord to my charger is broken so it takes forever to charge my phone. I also keep getting an error message regarding using a furnished charger and a quicker charge.
  • jasonscarterjasonscarter United StatesPosts: 1,819 ✭✭✭✭✭✭✭✭
    edited April 27, 2018 12:24PM
    Official charger and cable on the following page if it's the same as the A7: https://www.zteusa.com/products?cat=143
    If not, not sure what charger they supplied with the phone.
  • samsamhasamsamha United StatesPosts: 2,192 ✭✭✭✭✭✭✭✭
    You should be able to use any cable without major problem. Some cable do work better than others when comes to quick charging. the Z Max Pro comes with USB type C, if you want you can just buy it directly from ZTE's website. The charging adapter should be QC 2.0 but QC 3.0 should work as well.
