ZTE Blade X Can't multi-task?
Andrew_NAndrew_N United StatesPosts: 2 ✭✭
My older ZTE Grand phone never had these problems, but my new ZTE Blade can't even keep the internet browser open while I am checking emails, how do I fix this?
  • jasonejasone United StatesPosts: 1,895 ✭✭✭✭✭✭✭✭
    It's an aggressive task killing that cannot really be fixed. The only real solution I've been able to come up with is if you are multitasking to use the split screen feature to keep the apps from reloading.
  • SaltySalty United StatesPosts: 2 ✭✭✭
    I have the Z Max and it does the same thing. Like Jasone said, it's task killing software built into the phone to supposedly enhance the phone's battery life. You can try tweaking whatever settings you want, but the only way this will get fixed is if ZTE releases an update either disabling this trash feature or at least letting you choose whether or not to use it, which sucks because I'd love this phone if it wasn't constantly resetting my apps. At least I got the phone for free by switching to metro.
    Come on, ZTE. Get your shizz together.
