4 months later and issues
SKOLSKOL WashingtonPosts: 37 ✭✭✭✭✭
So far every day my phone freezes and I have to restart. I don't think this phone will last a year. Axon M
  • samsamhasamsamha United StatesPosts: 1,840 ✭✭✭✭✭✭✭✭
    hi, SKOL, so sorry to hear about your issue here. Are you using microsd card in the phone? if so, maybe try use it without the card in it for a few days to see if that could be the problem. Also, I know it's a pain but have you tried to do a factory reset?
  • wings4anniewings4annie United StatesPosts: 1,255 ✭✭✭✭✭✭✭✭
    @SKOL I have my AxonM, is slow to respond sometimes, but I did a factory reset, and so far it seems to help.
    Keep us informed
  • jasonejasone United StatesPosts: 1,903 ✭✭✭✭✭✭✭✭
    I've used one for more than 4 months and never had an issue like that. It might be a good idea to try clearing the cache from recovery or doing a factory data reset.
  • HingeHinge United StatesPosts: 8 ✭✭
    How do you clear the cache from recovery
  • mike2456mike2456 China Peoples RepublicPosts: 10 ✭✭✭
    What does the Freeze means ?
  • SKOLSKOL WashingtonPosts: 37 ✭✭✭✭✭
    I did a factory reset and everything is better
  • AnthonyTAnthonyT United StatesPosts: 3 ✭✭
    My phone does the same. I have reset in and factory reset it. But after a day or two the problem returns. Even with no apps but the factory ones on there.
