Connection
iampaydaymusiciampaydaymusic United StatesPosts: 1
Can any explain to me in details how to connect my zte blade Max to my zte quartz smart watch?? Thanks in advance
    hi, it is simple.
    Just download the Wear OS app from the playstore. Turn on the BT on your phone. Then start the app, then follow the on screen instruction as it will guide you through setting it up step by step. It should be simple and easy.
