How to turn on phone when it is on factory test mode while having a broken power button?
amisaacamisaac United StatesPosts: 1 ✭✭✭✭
I made the mistake of letting my phone die. I couldn't get it my phone to turn on, however I could see that it was at 18%. I pressed the down volume button and now I'm stuck at the FTM screen. I have tried pressing my power button in different positions. I'm extremely desperate as I don't want to lose any of my photos. Have any of you been able to turn your phone back on? I have a Blade X Max.
  • samsamhasamsamha United States Posts: 1,938 ✭✭✭✭✭✭✭✭
    hi, when you press volume down and power button and booted into FTM, you should be able to just long press the power button to exit out of FTM mode and boot like you normally would.
    If that does not work, try to hold the volume up button and the power button. Then once the phone reboot, let go of the power button. This will boot into the recovery where you can select reboot to boot the phone.
