ZTE MAX XL Firmware
brightboyz40brightboyz40 CanadaPosts: 2 ✭✭
Recently got a used ZTE Max Xl from a friend I would like to install original firmware to the device
where am I able to get stock firmware for this device ?
thank you
  • samsamhasamsamha United States Posts: 2,333 ✭✭✭✭✭✭✭✭
    hi,
    Typically once the phone has been reset, it should be running the stock firmware (assuming that whoever gave you the phone did not root the device or put a custom rom on it). So if you just want to get rid of the apps and data that is on the phone, just do a factory reset(under setting, there should be a option for factory reset) and it should be running stock.
