battery issue?
so out of no where the phone doesnt charge anymore.says 0%.at one point it charged to 3% then back down to 2%.i tried charging through laptop usb plus quickcharger.will a battery replacement from ebay fix it?
    First thing I would recommend is to try a different cable if you happen to have one.
    There is a possibility that the issue maybe the charging port. If you do see the charging icon when you insert the cable, and it displays battery is charging except that the battery percentage is not increasing, then  It does sounds to me the issue maybe battery is dying and replacing with a battery should fix the issue.
  • fpsfreak209fpsfreak209 Posts: 13 ✭✭✭✭
    thanks for the reply.tried cable #2 and same thing.
    ok with new cable it started charging again.crossing fingers hopefully it was a faulty cable that was causing the problem.
