ZTE Z933 Not starting up
I have a ZTE 933 that is not starting up.
Messages are:
E-cant mount cach recovery log--cant open cach recovery log--cant mount recovery last log--cant mount recovery last log--cant open recovery last log--cant mount cash last install--- reboot is not working.
looks like i have to find a download file for the bootloop, can anyone help where to get it from
    Hi, I do not believe that there is an official rom that you can flash to the phone that is available. Have you try to boot into recovery to see if you can factory reset the phone to see if you can get the phone to boot up. If that does not work, I would suggest check out XDA to see if you can find way there to help you to get the phone back and running.
