ZTE ZMAX PRO - not charging.
TechTech United StatesPosts: 2 ✭✭
Hey everyone. Have you had this issue: ZTE Zmax Pro Z981, new battery - tests ok. New charge port installed. Phone will not boot, or stay running without cord plugged into wall outlet. It will not charge, and battery indicator stuck at 50%. It does not respond or charge when plugged into a computer. I've left it for hours plugged into wall outlet and computer. Factory reset would be last option only.
    Tech After a repair/replacement a factory reset is your best option if it hasn't worked itself out yet.
  • TechTech United StatesPosts: 2 ✭✭
    I did a full reset, more than once now. Everything works, it just has to be plugged in to wall outlet to run and boot. Charge level stays at 50%, and it still won't be recognized by usb to computer. Any thoughts everyone?
