Finger Print and Screen brightness control Axon Mini
cf07cf07 CanadaPosts: 149 ✭✭✭✭✭
Lately finger print sensor seems to be on strike..hit and miss even after re learn new finger file. yes wake up is ON.
Any tricks to get finger print sensor wakes up faster.??
The brightness control is a total failure. Either preset or Auto. When woke up, it is just Dark. I have to touch the slider to wake it up.
It is very inconvient when you want to read what is on screen.
    @cf07 You may want to try cleaning the FPS with some rubbing alcohol. Oil from your finger and dirt/debris can cause it to misfire. You can also try adding the same finger multiple times which may help with accuracy.
    It's also probably a good idea to clear the device cache at this point. It may help with both issues as well.
    Will do whenI am back home
    Ok Cleaned the sensor with 70% alcohol.
    relearned finger again.
    cleared partition cache.
    No, the finger unlock does not improve.
    the screen brightness control seems ok. not sure after deep sleep.
    the brightness seems to be slightly better but not always.
    finger print still troublesome to wake up.
