blade z559dl
deano77deano77 United StatesPosts: 4 ✭✭
does anyone know how to get icons back that have disappeared. i have alfred camera which google play says is installed but cant find the icon same with youtube
  • samsamhasamsamha United States Posts: 2,127 ✭✭✭✭✭✭✭✭
    do you see the icon shows up in the app folder? If so, you should be able to long press the icon and drag it to the home screen if you want it shows up on the home screen.
  • deano77deano77 United StatesPosts: 4 ✭✭
    no but app reset brought back youtube but i need alfred camera back may just factory reset or hammer i despise android op sys i have working man hands and this swipe garbage takes 10 15 times throw it in the damn garbage
    Went back and got Alfred camera to install after app reset
