Blade T2 lte ZEZ559DL
jry1967jry1967 United StatesPosts: 4 ✭✭
How to remove developer options off my phone Blade ZEZ559DL . My phone says that it has a custom ROM on it
  • samsamhasamsamha United StatesPosts: 2,189 ✭✭✭✭✭✭✭✭
    hi, if this is a retail phone, then the developer option should not be turned on and should not come with custom ROM. I am not aware of any custom ROM for this device, can you post a screenshot for the About phone showing the build number?
  • DrakenFXDrakenFX Mobile United StatesPosts: 2,006 ✭✭✭✭✭✭✭✭
    @jry1967
    You mind posting a screenshot of the "developers option" ?
    Or if Does look like this at the beginning (look screenshot) , just tap the toggle and development option will be disabled.
  • jry1967jry1967 United StatesPosts: 4 ✭✭
    I can't get it back to the developer settings and it still says that it has a custom ROM on it
    You bought it from a retail store or someone else?
    Post a screenshot or picture of the "About Phone" under settings for us, so we can help further.
    A retail store and let a lady friend borrow it to text on for a few minutes
    Try to post a screenshot of About Phone. Go to Settings-->System-->About Phone. Then press volume down and power button together to capture the screenshot with the build number (which is all the way toward the bottom)
