Which is better for international use in Europe the Blade Max View or Blade Z Max?
Tech_XTech_X United StatesPosts: 2
edited June 16, 2019 4:46AM in Blade MAX VIEW
Hi. If I was going to Eastern Europe which phone would provide more frequency band coverage?
I've searched online and it's hard to find complete band specs for each phone. But it looks like the Blade Z Max Z982 maybe has more GSM bands including GSM 900 and 1800, but the Blade Max View has many more LTE bands.
Or are there other big 6" screen ZTE phone with dual front cameras that would work better in both the USA and Europe?
Any help appreciated. Thanks.
    both phones use same chipset so the radio bands should be more or less the same. Between the two, I would say go with Blade Max View since it's newer and it is unlocked already. You can use this site to see if the phone would work with the country that you would be traveling (just be aware that the information on the site may not be 100% accurate but it's a good place to check the information).
