Do I need a micro SDXC card for phone to work
jeanne51jeanne51 United StatesPosts: 2
No number on my Sim card
    no, you do not need microSD card in the phone to have it working. You just put in a compatible sim card and the phone should work. Who is your carrier, do you need to make sure that your carrier is supported.
