What speaker system works with spro?
KatrinaKatrina United StatesPosts: 1
What speakers/ sound system can be used with spro to enhance sound to reach large audience?
  • razor512razor512 United States Posts: 2,660 ✭✭✭✭✭✭✭✭
    Due to the outputs that is has, if it is playing media internally then you may be stuck with either using the headphone jack with an adapter that allows external speakers to connect to it, or using a bluetooth audio receiver. The audio will still be a stereo signal, thus if you are using a 5.1 speaker system, you may need to enable the stereo surround mode on any audio receiver that the speakers may be connected to.
