Axon 10 Pro 4G LTE Specifications
AerospacemanAerospaceman United StatesPosts: 1,502 ✭✭✭✭✭✭✭✭
edited August 29, 2019 10:46PM in Specifications
Hello Z-Community!! Below you will find the main specifications for the Axon 10 Pro. Most of these specifications should be understandable. If there is something you don't understand please don't hesitate to post a comment/question below and a Community Ambassador or another community member should be able to answer your question.
Bands:
LTE: 1/2/3/4/5/7/8/12/13/17/18/19/20/25/26/28/30/66/71/B34/38/39/40/41(2535-2655MHz)
UMTS:B1/2/4/5/8
GSM:B2/3/5/8
MIMO/Carrier Aggregation(CA):
2CA: inter-band B2/4/7/38/41/66
DL 2CA:B2+B2,B2+B4, B2+B5,B2+B12,B2+B66, B4+B4, B4+B5, B4+B12,B7+B7, B7+B12, B12+B12(12A+12A & 12A+12B), B66+B5, B66+B12
UL 2CA:B7+7,B41+41
DL 3CA:B13+4+2,B13+4+4,B13+2+2,B5+4+2,B5+4+4,B5+2+2,B13+66+2,B13+66+66,B5+66+2,B5+66+66,B66+66+2,B66+2+2, B66+66+66,B2+4+7,B2+4+12,B2+4+71, B2+5+30,B2+12+30,B2+66+71,B4+5+30,B4+7+12, B4+12+30,B5+30+66,B12+30+66;B2+2+4,B2+2+12,B2+2+71,B2+4+4,B2+7+7,B4+4+5,B4+4+7,B4+4+12,B4+4+71,B4+7+7,B12+66+66,B66+66+71;
DL 4CA:B2+5+30+66,B2+12+30+66,B2+2+5+30,B2+2+12+30,B2+2+12+66,B2+5+66+66,B2+12+66+66,B5+30+66+66,B2+4+7+7,B2+12+66+66;
Battery:
Talk:1500 min
Standby:640 hours
4000 mAh, Non-Removeable
QC4.0
Display:
AMOLED, 6.47“
Resolution: FHD+(2340RGB*1080)
16M color
3D,Notch
OS:
Android 9 (Pie)
Processor:
Qualcomm® Snapdragon™ 855 octa-core processor
Kryo 485 – 64-bit application processor with 2 MB L3 cache
Quad high-performance Kryo Gold cores:
     -Three Kryo Gold cores with a 256 KB L2 cache per core, Fmax at 2.419 GHz
     -One Kryo Gold prime core with a 512 KB L2 cache, Fmax at 2.842 GHz
Quad low-power Kryo Silver cores with a 128 KB L2 cache per core, Fmax at 1.786 GHz
SIM Card(s):
SIM 1: Nano
SIM 2: Nano, also supports MicroSD expansion
Memory:
8GB RAM + 256 GB ROM, (or 12 GB RAM + 256 GB ROM)
SD Card:
SD Memory slot expandable up to 2 TB (Use of SD card will only allow use of one SIM Card "SIM 1")
File System:
F2FS (Flash-Friendly File System)
Wireless Charging:
YES
Bluetooth:
BT 5.0
WiFi:
802.11a/b/g/n/ac  2.4 GHz/ 5 GHz
Fingerprint Sensor:
In Screen (Optical)
Cameras:
Rear Cameras:
48M+20M+8M PDAF(48M/8M),FF(20M)
Optical:3x
Digitial:10x
F1.7(48M)+F2.2(20M)+F2.4(8M)
Front-Facing Camera:
20MP, FF
Audio:
Dual Speaker with “DTS:X® Ultra 3D" sound.
USB-C to 3.5mm adapter included in box.
«1
