DEFAULT LAUNCHER BUG USING GESTURE (SWIPE) NAVIGATION
xphylexphyle United StatesPosts: 74 ✭✭✭✭✭
I just got the USA version today. I use Action Launcher and have assigned it as default. There's a bug in GESTURE controls that causes whatever launcher you have assigned as DEFAULT (in app settings) to revert back to the factory launcher when using "Gestures" navigation and swiping up from the bottom to go home. When I changed the gesture controls back to the 3 button controls (virtual navigation), Action Launcher worked fine and stayed the default launcher even when I pressed the home button. But when I changed back to "Gestures" navigation, every time I swiped up from the bottom to go home, the factory launcher replaces my Action Launcher. So if you want your favorite launcher to stick, don't use swipe navigation. Can someone please bring this to the attention of ZTE. We need a fix.
