My zte blade x max battery wont charge
WasatchcarsWasatchcars United StatesPosts: 1
I just got my zte blade x max and I was using it 2 apps running Waze and podcast. The battery ended up dying.
I put it on a charger nothing, I tryed holding power button for a long time, both volume & power button at the same time, Plugin into computer nothing worked.
When I am holding the buttons the light in the home screen button will come on and flash but not while it is just plugged in not holding any buttons.
I was working great prior to this happening
Any help?
  • samsamhasamsamha United States Posts: 2,312 ✭✭✭✭✭✭✭✭
    hi, sorry to hear about your issue.
    Have you try a different charging cable or charger? Maybe leave the unplugged for a little bit like overnight and then plugged into wall charger to let it charge for like 30 minutes then hold the power button to see if you see anything on the screen.
