Blade T2 Lite
rjalmomrjalmom United StatesPosts: 1
Did a system update today. My phone will no longer recognize my SD card. Says partition something or other failed when I try to reformat. I've even tried to take it out and put it back in and no luckm
    can you try the card in a desktop or laptop computer to see you are able use it? If the card works fine on a computer, maybe try to format it on a computer then tried it in the phone to see if it works.
