Bluetooth Media Problems with 2015 Cadillac Cue
david_l312david_l312 Posts: 24 ✭✭✭✭✭
I can't get the bluetooth media (bluetooth phone is fine) working in my 2015 Cadillac SRX (Cue system). Media audio works fine in a 2018 Tesla M3 (was even using an advanced CODEC).
In the Caddy, the phone bluetooth device shows media audio (and it's turned on), but the Caddy says "no devices available" when I try to select the source. Once it did try to connect, but no sound came out.
The phone is on v1.11.
The bluetooth has been a bit touchy with an LG headset too.....
Turned on headset, phone and headset said connected. When I started to play music (AT WORK), the sound still came from the phone speaker. In a panic I mashed Vol down which lowered the BT volume having no effect on the unwanted attention I was getting. Finally found managed to stop the playback, then power cycled the headset and it worked fine the 2nd time.
