What the best power plug to use?
Hey guys. How are you.
Can help me? I bought a ZTE Quartz but don't received the power plug. Just the dock.
Those i alread have dont work corretly with the Quartz. The 1Ampere dont charge. The power plug with 2A charge just to 60~70% and to so long (12h) to charge
What i have to do to not screw up the battery and get the 100% charge.
Thanks
    To my knowledge it doesn't require any special power brick for charging. I have my plugged into one of those 7 port multi chargers and mine has always charged reliably and worked fine for the past two years.
    In my experience, it usually only takes about an hour to fully charge it. Have you tried performing a factory reset on the watch and draining it all the way to 0 and charging it up. Only reaching 60-70% and taking 12 hours to charge doesn't sound typical no matter what charging brick you use.
