How could turn on Vibration on Incoming Calls at ZTE Blade Zmax
VajeeshVajeesh United StatesPosts: 1
Hello Everyone,
I am new user of ZTE Blade Zmax and having problem about how to fix vibration on incoming call.
could anyone guide me how to turn on Vibration on Incoming Calls at ZTE Blade Zmax?
Thanking You
    Under the Setting-->Sound-->Notification mode, you can set it to Vibrate when ringing. Additionally, if you open the dialer/phone app, and tap on the 3 dot menu for settings. There under sound and vibration, you can check "always vibrate for calls".
