Battery Replacement
srvsrv MsUnited StatesPosts: 6 ✭✭✭✭
Can you replace the battery in a ZTE Grand x4 Z956? I If so, how do it & what's the best tobuy one
    hi, the battery for this phone is sealed inside and not user swappable. While it is possible to replace the battery yourself (google online for guide to take apart the phone), it requires a little bit of work and taking the phone apart. So if you are tech savvy, you could follow the instruction carefully to replace it yourself.
