How to add widgets to home screen on Blade A5 2019, (Android Pie)?
I try long pressing in a free space, but only get the options "home settings" "shortcuts" "wallpapers", nothing about widgets anywhere on the screen. I'm mostly interested in the weather clock widget, and this is just driving me nuts. I hope one of you can help me out here.
Please note, the phone is fresh out of the box, only been used for a few days, and this has never worked.
Thanks,
M
  • samsamhasamsamha United States Posts: 2,309 ✭✭✭✭✭✭✭✭
    hi,
    I don't have this phone to test but have you tap the "shortcuts" to see if it is possibly where you can find the widgets. Typically, for ZTE phone, if you long press the home screen, you will see the option showing up on the bottom: Wallpaper, Widget, Home Settings. So it is possible the shortcut is where you will find the widget.
