Axon M - "Your device is corrupt. It can't be Trusted and may not work properly." - HELP
GaladrielGaladriel United StatesPosts: 10 ✭✭✭
Every once in a while (and getting more and more often), I get the following message with a black screen. Items between the asterisks are what is showing on the screen, otherwise, it my comment.
Start>
Continue boot
< More options
Press volume keys
Visit this link on another device:
g.co/ABHg.co/placeholder
If power key is not pressed:
your device will power off in30 seconds
the "g.co/placeholder" is in red text. All the rest is in white.
1.     If I press the volume keys, I get this:
Options menu:
Press volume key to select, and press power key to select
Power off
Restart
Recovery
Fastboot
Back to previous page
2.     If I press the power key, I get:
ZTE
POWERED BY
Android
Followed by the image of the battery, with however much charge and the 'ON' button. I push the button and it will either:
A.)  Go through the whole process again, except it will boot up correctly after
OR
B.)  It will go ahead and reboot normally
But then, sometime later, I need to go through the whole thing again.
I found somewhere to do a factory reset by powering it off after it has reached at least 50% power, then hold down the 'Power Up' button and the 'Power' button at the same time to get a different boot menu.
I did that and it seemed to help a little, but only by making the time between shut-downs a little longer.
So, other than getting a new phone (I still have a few more months on the contract and it is out of warranty), does anyone ave any ideas of something else I can try?
Thanks,
Galadriel
