Wireless Earbuds
scoob20scoob20 United StatesPosts: 16 ✭✭✭
Does anyone know what type of wireless earbuds I would need to look for so that I buy ones that work??
I see there are some requirements and am not sure if the Axon 10 has to have any special type of earbuds like Bluetooth 5.0?
    You can use any wireless earbuds. BT should be backwards compatible. The benefit of BT 5 (if both devices supports it) is that you may get better battery life.
